Lets see what you EDGE modders look like!!! Post pics of your EDGE mod
here are a couple of pics,
RXP motor. Turbo, 18lbs of boost on pump gas. Motec
M400 ECU. About 320 HP right now, should be up to 400 by next season. Fastrax tube chassis built to fit the motor.
It's about 520 with oil and coolant.
don't feel much weight difference between it and the 04 escape I have. Lots more power though!!
Running a 174 16 wide track
OK its really a prox but close enough! 1200WC, holz prox chassis, 144, CS pipes fitted by myself and a friend around 20hrs.
Dont have pix of the 800 though, just your typical orange proxr 800 with twin ceramic slp's.
Here's our old Edge effectionately known as BLING
Many many great rides on this one and she is still going strong. Started life as an 02 600 RMK crumpled up mess from Jellystone with thousands of miles. Bulkhead was curled up and back in the front quarter from some tramatic incedent. We stripped it to the bone and literally replaced everything but the bulkhead/tunnel. Got it beautiful and just finishing up the assembly which was putting the final rivets into the pan and the SUM BICH didn't fit! (swore threw tools and maybe cried a little) Tore it all apart to see that the bulkhead was still way way out of wack. MASSIVE re-engineering (that means auto frame alignment chains, pullies, smash blocks, and the biggest hammer you've ever seen..plus re-welding) Still misaligned and semi catiwampus BUT IT IS MAGICALLY PERFECT in that the thing runs like a scalded dog and doesn't use up belts. I guess we stumbled onto the exact correct geometry of engine/clutch mounting to bulkhead alignment. In the old days it was easily one of the fastest normally asperated under 800cc sleds out there. (proved it far and wide) Won many many a drag race and even a hillclimb on her!
660 Polaris small block VES Carls Performance Engine
SLP/SLP exhaust
Holz Arms
Carls/Fox Zero Pro Shocks
Wildchild custom steering hoop to fly bars with odi grips
Boss Seat
Mountain Machines Big wheel Kit
Custom Poly hood with our custom vents
Digatron Data Acquisition Gauge
Simmons skis
Camoplast 2.25 x 144 Finger track
Better Boards powder black running board inserts
447 lbs wet with coolant no gas minimal oil
