R
rotax
Oil Leak/Seaping from Oil Resiviour (Nytro)
EDIT: I pulled the can, found the crack...and slopped JB Weld all the way around. Will see how this works.
CRACK
JB WELD
I found a slow oil leak/seap from the oil resiviour, underneath where the large hose connects to an elbow. After very close inspection its coming from between the 'can' and the elbow. See pic. The arrow doesn't point to the exact spot, its actually above it, where that piece connects to the can itself.
Anyone have experience with this? A fix? I double checked bolts, loosened and re-tightened. Wondering if I just need to replace this seal?? Assuming theres a seal.
Is it just a matter of draining the oil? Pull the bolts, replace seal/gasket, and replace?
This is NOT a breather oil leak.. I have looked it over very close, and felt and found the leaking seal.
NOTE: Looking at the pic notice the alum block that the elbow connects to, its leaking from the TOP of this block. Looked at a buddies Nytro and his is, and has been completely dry in this location.
CRACK
JB WELD
