Just for your information.
Sent out a set of build sheets to a Snowester. He sent the shocks out to have them revalved.
I received a PM that they weren't working. Finally he sent me the RTS. The RTS was the worst performing shock of the 4. It had the wrong spring. They installed an IFS spring on it. The valve shims that were replaced were either the wrong size or well used burned out shims. The bypass hole was also drilled to large. He will need to replace it $$$$$. They need a proper set of drills for this task. The end washers were also of the wrong diameter.
Long story short, I cannot guarantee you will get a proper rebuild from anyone other than Rogers Sport Center(307-587-6818), myself or do them yourself. In a previous thread, I stated you can only get the 1.200" shims from Walker Evans or PI. You cannot replace this shim with a 1.250" OD size.
TRS
TRS
