Project 2015/16 Arctic Cat M 8000 SnoPro Build – Part 2: Gears, Clutches
Ski-Doo Klim EZ Lynk
Published online: Apr 08, 2015 Arctic Cat Steve Janes Viewed 424 time(s)
Web Exclusive
(EDITOR’S NOTE: This is third in a series of articles about converting a 2015 Arctic Cat M8000 SnoPro into a SnoWest Forums 2016 Project Cat giveaway sled. Throughout the summer and fall we will be working with SnoWest Forum members to build the perfect snowmobile … and then we will give it away to a Forum member at the end of the build.)
http://www.snowest.com/2015/04/project-2015-16-arctic-cat-m
For most snowmobilers, the bulk of the transition between 2015 and 2016 Arctic Cat snowmobiles will focus on the front and rear suspensions. However, what we really noticed was the effect the change in clutching and gears had to do with how the snowmobile operated in the trees.
True, the front suspension changed how the 2016 SnoPro carved through the snow and sidehilled. And the rear suspension changed how it got up on top of the snow. But it’s the clutching change that made the 2016 more user-friendly.
To upgrade the 2015 drive system to Team Rapid Response/Reaction clutches, you had to start by replacing the jackshaft. And since we’re going through the bother of pulling the jackshaft, it made perfect sense to change to Borg Warner gears and chain (used by the Team Arctic racing crews).
The main reason we wanted to make the change to Team clutches was to lower and broaden the engagement range to allow the clutches to work better in tight and technical situations. Cat clutches always had a tendency of slamming in on engagement. For aggressive riders, that’s perfect. But for those of us who like to ease into certain situations (like crawling up a trailer ramp), this all-or-nothing sensation was a bit unsettling.
Arctic Cat made the change for its stock mountain sleds and for 2016 the clutches will engage about 500 rpm lower and offer more of a smooth transition on engagement. It will also deliver a broader powerband to allow the clutch to work better and pull harder.
Another bonus with the Team clutches is that they run cooler, which improves performance, increases roller life and increases belt life.
As for the Borg Warner chain, it will be stronger, more durable and feature less stretch. It’s the same chain Cat has used on its race sleds since 2004.
Here is what we did for our latest install.
1) Remove the hood and then the pipes to open up access to the chaincase. Also remove the drive belt and the primary and secondary clutches.
2) Remove the torque plate. It consists of four bolts behind the drive clutch and six bolts behind the secondary. (On the bottom bolt behind the drive clutch, be aware of a concaved washer that is located behind the plate. You will want to catch it when you remove the plate and know what direction it goes so you replace it properly when you put things back together.)
3) Moving to the chaincase, first put a catch-pan under your sled so when you crack open the chaincase you don’t have a mess.
4) Disconnect your oil pressure sensor and odometer cable and move them out of your way.
5) Remove the 10 black bolts that hold the oil reservoir on. Once the bolts are loose, allow the oil to puddle up in the bottom of the belly pan and find its way out to the catch-pan.
6) Remove the chain tensioner by pulling it straight off.
7) Remove the top gear. This involves two C-clips that hold the gear in place, and then another C-clip that holds the washer that attaches to the jackshaft. Now you can remove the jackshaft.
8) Remove the bottom gear by removing the C-clip that holds it in place.
9) Now we’re ready to install the Borg Warner gears and chain. First install the bottom gear, then install the chain. (Locate the black link on the chain and make certain it is on the outside.)
10) Now install the jackshaft. Be sure to put in the washer before you attach the C-clip. (The washer serves as a spacer to eliminate vibration. If there’s still a little play in the jackshaft, you may want to add another washer before proceeding further.)
11) Install the top gear with the chain. There should be a little play in the chain … that’s what the self-aligning tensioner is for.
12) Install the chain tensioner. The spring will press against the case and you can then preload the tensioner. (You want to start with the chain a little loose as you put things back together because it will always tighten up. If you start with it too tight, there is no way for it to loosen up.)
13) Install the torque plate (remembering to include the concaved washer that is located on the inside of the torque plate). You want to start every bolt on the torque plate first before tightening them up. They require 14-ft-lbs of torque on the six bolts behind the secondary and 30-ft-lbs of torque on the four bolts behind the primary.
14) Install the chaincase. Again, it’s best to start all bolts first and then tighten them up to 25-ft-lbs of torque.
15) Add 12 ounces of oil to the chaincase. Reattach the oil pressure sensor and the odometer cable.
16) Install the clutches. The secondary clutch comes in two pieces with washers and spacers. Torque the primary and secondary clutches to 51-ft-lbs. Install the belt.
17) Install the pipes. (Put the long portion of the springs toward the engine.)
18) Attach the hood.
We didn’t do any clutch work at this point. Once we’re ready for the snowmobile to get on the snow, and after we’ve made whatever modifications we end up doing with this project Cat, then we’ll be able to fine-tune our clutching.
  • Although Forum Moderator Christopher Parrett was technically “helping” on this project … I think this is about as close as he got to getting his hands dirty—holding a camera while he shot a close-up of Shay Smith doing all the work.
f you’re going to steal parts, at least steal the good stuff. Although there’s been a lot of Forum discussion about going to a belt drive, we thought that given the opportunity to acquire Borg Warner chains and gears, we better make the most of it.
And when it comes to clutching, the Team Rapid Reaction secondary clutch is definitely the way to go.
To remove the hood, the first thing you need to do is pull the cable housing attached to the instrument gauge. For the hood itself, there will be six torque screws to remove. Four are the same length and the two under the nose are longer.
Once the hood is removed it will be easier to remove the pipes, clutches and chaincase.
To remove the belt, you need to take out the bolt that holds on the secondary clutch, reverse the silver metal spacer and then put the bolt back in and tighten it to spread the sheaves.
On the chaincase, remember to remove the oil pressure sensor and the odometer cable and move them out of your way.
With the clutches removed, you can now get at the torque plate.
Before you crack open the chaincase, make certain you have a catch-pan to collect the gear oil. There are few things worse than having gear oil on the floor of your shop.
With the chaincase cover removed, you can get at the chain tensioner and gears.
If you look closely on the upper right side of the chain you will notice the darker link (about fourth from the end). Remember to have this link facing out when your replace the chain.
With the chain in place (notice the darker link in the middle of the chain) it’s time to replace the chain tensioner. Don’t get your chain too tight at this stage … it will automatically increase the tension as needed.
Although many mechanics will tighten bolts up to where they think they should be, you really ought to invest in a torque wrench and set bolts to manufacturer’s specs.
Once you’re ready to replace the clutches, remember the secondary will go on in two stages.
This is the second stage of the secondary.
Use a torque wrench on your clutches to meet manufacturer’s specs.
When installing the springs that hold on the pipes, be sure to have the long part of the spring facing the engine.
2015 M8000 Build
I must say when this snowmobile is done it would be a most excellent addition to ones snowmobile collection bar none! :face-icon-small-hap
When it comes to backcountry riding the 16 clutch and gear setup is not the Best! If your serious about getting into technical backcountry riding you need the clutches to engage lightly then rev to high r's before shifting so you have full power on demand. With it setup like that it comes down to throttle control.
As my 16 came setup it wont do that, feels like trail clutch, in tech areas if you need full track spin now it wont do it because it shifts before the r's hit. thus you have to hang on a second longer before it spins up.
My 14 with a 911 cover, sw 120-310 spring with 63g cat weights, I also run MDS weights for bit more pull, (the way I had them setup it hits fast and pulls like a turbo), a machined secondary by mountain valley motor sports in Cody, WY, at 10,000ft works great.
I also geared it up to a 2.42 ratio with a tki belt drive when I installed the 3" track with the stock 8 tooth drivers.
Once the clutching is fixed!!!!! it has no problem pulling the track or gears. In fact it will pound a hole in the stock 16 and the tech riding is far easier.
So again, I can't sit by and listen to this bulzhit about low gears and clutching that as you stated for backcountry riding works.
If you want to say it works great for beginner level backcountry.... I'll stay quite.
Now on to the skid, they finally did what I've been talking about for 6yrs and what kmod and others have done for way longer. The rails put the track on the ground at least 2" forward. This gives a better rider input because it puts the track more under your feet. It also puts 2+ more inches of track on the snow, in effect it will float more like a 158" track but still handle like a 153.
Thank you Yami for that.
The caster on the new spindles is great. Now on a sidehill the outside edge of the ski sits flatter to the hill, unlike the old style that just tried to dig in. although the ski rubbers are dang stiff new, maybe to much.
The shocks (evols) hmmm. well at least I have something to start with. If you set it to factory specs its a pogo stick, bad.
You want it to be a backcountry sled focus more on narrowing the boards and add some steering to start. then drop as much weight as possible.
I've put the burandt boards on my 16 and steering mod. It's ride-able now, time for some serious weight loss!
With everyone doing away with the auto chain tensioners in the last couple model years why not go with a manual tensioner with this one? Are the 16's a different design than before? Never had a problem with my auto tensioner in my '14 PC but just curious.
I never had a problem with the tensioner,but when I took mine apart the chain had 7 broken links.This was at 500 miles.
holy **** 500 miles . if they are all broke on the same side it gear alignment but if it all over i guess you have 400 hp .
This is the kind of build that takee to artic cat camp, been waiting for a long time. Please pick me to try it!!!
So, would you like a brand new 2016 Arctic Cat sled for FREE?
ENTER HERE
http://www.snowest.com/forum/showthread.php?t=394235
I sure do love my 14 m8000 but a 2016 would be so much sweeter
911 clutch cover works well for stock clutch with oversize bearing and rigid machined aluminum cover material.
