C
coug66
engine repair advice
I have a nylon ski rope stuck in between the piston and the cylinder.
How it got there?
I was locking the motor to remove the primary to tune it for my elevation. fill the cylinder with rope just before top dead center.
the first engine lock went fine to remove the clutch. I reversed the motor and the piston came up to lock it. problem was on the long stroke the rope got caught between the front of the exhaust port.
engine is stuck and the rope is so tight I can't move the motor or pull the rope to free it.
would you remove the cylinder bolts and pry the cylinder up against the case?
or would you bang the piston down with a soft mallet and a secondary hammer.
or another tip?
I am waiting on rings, I took the head off since I am getting it stripped to do a ring change.
How it got there?
or another tip?
