I get lots of PMs and stuff about what to do for a 900 skid...to make it better, stiffer, react to jumps, climbing ect ect..
How many of you guys have a sagging a$$ rear skid? it sits low, wont rebound up, you bottom out...you cant afford better shocks, cant afford a timbersled/holz/zbroz skid but want a BOMB setup for under $200...here you go!!!!!!
NEW torsion springs (OEM Polaris part) are around $80 each (need 2)
NEW 225lb spring (OEM Polaris part) is around $35 (need 1)
I started this thread few yrs back I just realized its only on the Polaris IQ section, and not the 900 section where most of the PMs are coming from..so refer to this link, but here is also a brief run down of what to add...
http://www.snowest.com/forum/showthread.php?p=3491422
now mind you..if you get other torsion springs (rates) then suggested, I don't care, that's on you but it was never suggested. I promise you (ive done this to the tee) and its by the BEST most IMPROVEMENT to the 900 skid you will ever do, trust me.
Here is a great post from Curt at FTX Motorsports.
Quote from MountainHorse
I also have found that when your track starts to stretch over time, I was running out of axle adjuster room and installed 6" upper idler wheels and it was awesome, never looked back..FYI
You will also know if you have the 225lb front track spring easily, there is a rubber boot/cover on the shock/spring installed from the factory...the OEM spring has a tapper and it gets wider in the middle then the top and the bottom, so the boot is very tight on the spring...the 225 spring is same width throughout and is skinnier, hence the boot is loose when installed and will spin
Below is the Part information for the torsion springs, 225lb front track spring and pics to show you the OLD springs, 225lb spring and the scissor relocation mod.
Torsion Springs Part info:
7042079-067 Spring, Torsion, LH, STD [.375/47 °]
7042080-067 Spring, Torsion, RH, STD [.375/47 °]
225lb front track spring part info
#7041822-067
Make sure and try our scissor relocation of 5/8" BACK-you'll be surprised how well that little change works with these springs
"You should also consider the 7042079-067 and 7042080-067 torsion set. They use a tighter spring leg angle which gives you a little more preload at the top of the skids travel. This helps a couple things...it allows you to run the spring on a softer setting and still supports you and the sled properly which extends the life of the spring. The spring will also have more effect at the beginning of travel which helps eliminate the dead spot all these skids have-this un-sprung/un-dampened area of travel is a big reason why the IQ was a bit on the wild side with weight transfer-to much scissor collapse right off the bat.
These are our go to springs for any one over 225lb (which I'm one of by the way!) I have a full season on them in my turbo 163 and they are still on the soft setting-haven't had to add any more pre load since installation which indicates that they are not "sacking out".
From what we talked about... the 47 ° angle initiates the suspension earlier... so that should improve the overall function of the skid and make it less wheelie prone and remain in control under power.
These springs have been around since at least 2004 from what I can see.
In fact.. they also make a 47 ° .359 spring for the lighter riders that should also improve the function of the skid.
#7041822-067
![shock_zps874fb1b8.jpg](http://i955.photobucket.com/albums/ae37/guidoxpress/shock_zps874fb1b8.jpg)
![225spring_zpsb6083dba.png](http://i955.photobucket.com/albums/ae37/guidoxpress/Misc%20Pics/225spring_zpsb6083dba.png)
![attachment2_zpsc61cb41c.jpg](http://i955.photobucket.com/albums/ae37/guidoxpress/Misc%20Pics/attachment2_zpsc61cb41c.jpg)
![attachment_zps8430d5fe.jpg](http://i955.photobucket.com/albums/ae37/guidoxpress/Misc%20Pics/attachment_zps8430d5fe.jpg)
![attachment3_zpsb41fb6d7.jpg](http://i955.photobucket.com/albums/ae37/guidoxpress/Misc%20Pics/attachment3_zpsb41fb6d7.jpg)
