I am selling my towable shop. Located in Thornton, Colorado
Specs are as follows:
2012 Double R custom built "All Sport" Trailer.
Year: 2012 Make: Double R Model: 8629AS7K
8'6" x 29' All Sport, 24' Box, 7' nose
GVWR: 14000# 2-7000# 8-lug axles, ST235/80-16" Radial Tires, 4-Wheel Brakes
Aluminum Wheel Upgrade (Set of 4) - Spoke Style
8 Lug Aluminum Spare Tire Pkg: Installed p/s up high rear
4' beavetail
Sloped interior fender wells to be drive on/drive off
Additional Height to Acquire 7' Inside Height (per ltf)
Grey Vinyl Wall Liner I.L.O. 1/4" Plywood
White Vinyl Ceiling Liner
Insulated walls and ceiling
2" Insulated Floor Per/SQFT
42,000 BTU Forced Air Furnace Non-Ducted
Includes: LP detector, wall thermostat, deep cycle battery, cabinet built around furnace to accommodate furnace only.
10 Gallon Propane Pkg., Each Tank is 40 lbs - installed on tongue
Includes: Dual 40-lb (10 gallon) Propane Tanks, Bracket Auto Changeover Regulator, Hoses,Valves, LP Detector
110 power pkg w/50 AMP Service
Includes: 50 AMP Breaker Panel, 50 AMP Service cord, 4 - Interior Duplex
Receptacles, 1 - Exterior GFI Duplex Receptacles, 4 - Dual Bulb 48" Fluorescent Light
Fixtures, Single Light Switch
4 Exterior Load Lights (12V)2-front ramp, 2-rear ramp wired for back-up lights
Upper and Lower Nose Cabinets
Add structure to lower cabinet to accommodate Vise to be installed by customer. Install plate on end furthest from nose on Pewter counter top.
24" x 20" windows tinted w/slider and screens 1-side door on d/s, 1-centered in
between fuel doors on d/s (normal height location), 1-3' from straight wall on p/s, 1- 4' from rear of trailer on p/s
Nudo Flooring
2 Fuel doors
1 Wire for A/C in both 14" camper vents
Generator Compartment in lower nose cabinet w/generator door, vented bottom - See
Cummins Specs for Gen. Size. Customer to install Gen
Automotive Undercoating along any exposed underside steel and tongue
Steel bracket to work as winch for snowmobile rated at 500# capacity
E-Track Recessed on Wall 2-rows on each side wall, 12" from floor, 48" from floor
40 Gallon Fuel Station/Fuel Cell for Generator
Includes: Fuel Pump, Deep Cycle Battery, Fuel Gauge, Gas Hose, Nozzle, Lockable Storage, gas line to generator compartment
1 Diamond Plate Trim 6" high going down both sides of interior walls
6" tall diamond plate on interior side walls
8" Trim Package - Exterior side walls
16 Exterior L.E.D. Marker Lights 8 additional down both sides of trailer
4 Motorcycle Wheel Chocks Recessed
Onan Marquis Gold 5.5kW Gas RV Generator Installed w/remote start, wire harness,control panel and hour meter.
Color: Black front and Roof/Bright Annealed Stripe/Red Rear and Rear door, Black
2 D-Rings 6K# Rated Recessed Swivel
9 D-Rings 1200# Rated Surface Mount
1 Centerline Equalizer Hitch and ball, w/welded on brackets
Brand new set of tires, everything in perfect working order. The reason I am selling it is simply because I do not need a trailer like this any more and I'd really like to have my truck a lot closer to being paid off than it is right now.
$18,000
PM if interested.
4' beavetail
Nudo Flooring
2 Fuel doors
$18,000
PM if interested.
