This is a feeler thread to see if there is any interest in a few of my engines. These engines have not been run and are in new condition.
727 Trail engine, I have 2 of the below configuration:
600 HO cases, trail ported
600 HO cranks, just gone through, new bearings, trued
New 726/727 cylinders with trail porting
New Pistons
12.5:1 or 13.4 compression domes
Bored carbs
600 HO igntion with PERC
Stator/flywheel
Recoil
$3500 Ea.
Polaris 797 Long Rod
70mm crank with BB800 136mm rods
797 cyls with trail porting
HO case with Trail Porting
New 800 BB pistons
Bored Carbs
12.5 or 13.6:1 domes
PERC Ignition
Stator/flywheel
Recoil
$4500
Polaris 726 race engine built on VES case:
New crate engine has not been run
26cc domes, requires 114 Octane fuel
has stator/flywheel
No ignition, reeds, carb boots/carbs, recoil or exhaust
Head shell was removed to be tapped for DET sensor, will be reinstalled prior to shipping
$2500
Polaris 600 HO, 1800 miles
New Pistons
New Crank
all new gaskets, seals, wrist pin bearings
600 HO ignition
Stator/flywheel
Recoil
Carbs
Y-pipe
$1900
600 R engine with PERC
600 R cyls (08 castings, 1 cyl is replated, 1 is used)
600 HO bottom end
70mm crank with 132mm rods
Wiseco pistons (F/M 600 piston)
600 HO Ignition
stator/flywheel
38mm carbs
The case/crank in this engine has approx 2 hours run time on it. Has deburred rods that have been polished to reduce stress risers and make a stronger rod.
$2300
New Pistons
Bored carbs
Stator/flywheel
Recoil
$3500 Ea.
New 800 BB pistons
Bored Carbs
PERC Ignition
Stator/flywheel
Recoil
$4500
has stator/flywheel
$2500
New Pistons
New Crank
600 HO ignition
Stator/flywheel
Recoil
Carbs
Y-pipe
$1900
600 HO bottom end
600 HO Ignition
stator/flywheel
38mm carbs
$2300
