figured I would put this together so I don't loose the info. Most of the wheels on the stock rear suspension do not have replaceable. The ones that do are the middle wheel on the rear axle, and the two wheels on the rear tunnel mount. I think the 2010 sled has removable bearings... bought fricken time..
Anyways, here you go.
Rear axle wheels
O.D. = 7" I.D. = 20mm bearing width = 12mm
rear tunnel mount
O.D. = 7" I.D. = 25mm bearing width = 15mm
spring holder wheels*
O.D. = 5 1/8" I.D. = 25mm bearing width = 12mm
front track shock mount wheels*
*I am not sure on the wheels, I thought they where 5 1/4", but I measure them at 5.1 inches or 130 mm. Not sure what size they are called, but since 1/8 = .125, that is what I am going with 5 1/8. Maybe they are just 5" wheels?
Anyways, I hope this info helps someone.. regardless, the beer tasted good while writing this.
happy modding..
Rear axle wheels
rear tunnel mount
happy modding..
