Hey guys, I didn't wanna post up much on this build (hoping for more of a suprise) but everything is going so well and fitting as planned I thought I would share. The build started about a month ago when I was working on my Apex motor and decided to set it in a spare tweaked chassis that I had laying around to find it fit amazingly well. As I looked everything over the only hinderence was the steering and figured I can work around that. I snagged up a full Apex motor for what I thought was a fair deal (Thanks Wes) and decided to get the ball rolling. Down to bare bones went the 163 chassis and and things were happening. First was to mount the Yammi chain case. I wanted to retain a good layback on the engine, use yammi belts and leave myself room to go over the chain case with a header as a last resort. As the yammi chain case is slightly shorter than the poo I decided to drop the jack shaft .25" into the tunnle to keep use of the stock driver lower holes. I welded the left side jack shaft hole up and then i cut out the tunnle and new bearing hole. I made dished piece of aluminum that was welded in for the shaft channel as well as the solid bearing holder on the left.With that looking good and out of the way next were motor mounts. I didnt want to skimp here nor over do it but would rather be safe than sorry. As you can see by the pics the are beefy as are the rears. The integrity of the rest the chassis is in ? but do have some minor bracing planned to help it out. After hrs of time figuring out exact engine placement the mounts were welded in.
As of now the motor and chain case are in place. I am taking the shafts to Fargo to get cut to length and resplined. In the mean time I will be workin on a turbo manifold layout and steering. A side mount will be the easiest as I have BD one but fabbing up a tank and doing the mid mount may be the way to fly. The steering will go over the motor and drop in like a IQR.
Sled will be set up with Timber Sled front and rear, stick with 162-163" track and a 2871r on the turbo setup. The motor is in the air as the one I bought is being rebuilt with carillos and JE's and my original motor is head shimmed with cam mod and low miles. Was planning putting the built motor in the apex but if enough BS flys it may need to go in the POO.
I hope you guys enjoy my build and will be posting with progress. ANY compliments are appreciated! Haters, I'll see you on the hill!
