R
So I tore into the secondary on my 09 to put in a shift assist and rollers. Even with heat I tore up some of the bolts. I could probably put them back in but next time will be a real PIA if I dont replace them.
Can you use a full size allen cap screw (10-24) instead of those stupid torx ? My only worry is the screw heads will hit the DD when shifted all the way out ?
I cant be the first one to run into this![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
