how to clear sevice notice
after my new reflash and some pipe playing i got my sled close to dialed in..im still low on rpm`s but now the 60hour service is on the gauge and i cant save my top rpm for tuning..how do i clear it so it saves top rmp or speed?
Look in your booklet that came with the sled and under Instrumentation, it will give you the info on how to clear it off. You have to hold the button and it will move in 20 hrs increments until it reaches 200 hrs and then it should show "Off" on your screen. Yup, that button is a PITA!
Hope this helps.
push the set until you see service and the interval, then hold the set button until it starts blinking, then push it again intil you pick the desired amount of time or until it says off, then push the mode button to go back to which ever display you want.
