This a bit of a long story and this my first Yami and first boosted sled. I have owned numerous sleds but this is new territory.
Was riding for about 5 hours Sunday (first ride on the nytro) about +5c set up snow. Sled pulled so hard I couldn't even think about looking at gauges as the snow was pretty set up. At the end of the day was turning donuts and tipped it over on its left side. Was on its side for about 40seconds before I could get it straighten out. Leaked out approx 700ml (3/4 quart). Got oil all over the belt and clutches. Cleaned it up as best I could. After that sled was definately coughing and not pulling full boost. Seemed to clear up a bit on the trail ride down. Was not smoking oil at all.
Next day up the trail (boulder) it was still coughing a bit but cleared up and was pulling hard throughout the day. Around noon was doing a few pulls working the sled somewhat hard then came down parked it in the shade as it was closer to +8c and not a breath of wind (behind turbo hill-whatever the elevation is there). Parked for close to 1/2 an hour. After lunch fired up the sled and within a sled length was coughing and sputtering. and after about 100 ft it bogged then idled down and finally quit. Hit the key and it would start (without touching the throttle )then cough and sputter and slowly loose RPMS then die. Did this a few times no improvement. Nothing on the main guage no codes no lights. MCX just comes with a boost gauge.
Pulled the panels off and had a look no leaks and nothing disconnected. Oil was full and lots of coolant. Pull the power lead off thinking it may reset something electronic?? Checked the hose coming to the mcx box nothing inside no water. After about 20 min fire it up and died again.........tried once more seem to be idling turned it around drove 100ft and seemed to running again?
Put the panels back on and headed closer to home. Once closer to the cabin did some testing and again it seemed to coughing at WOT and was pulling approx 13lbs boost instead of 15. Max I could seem rpms was 8000. Now when it was pulling harderI know it was hitting 15lbs and no idea what RPM because it was my first weekend and was pulling like an ape!
Once back to the cabin let it sit again for about 20 min or so and on the trail ride down seemed to be better but very hard to test. It would pull 15 lbs but could not see the RPMS but did "feel" like it was pulling hard. Again it was downhill most times and hard pack trail.
It really felt like it was starving for fuel, my guess was a blocked fuel filter or failing pump?
Good fuel 91 from shell with 4 gallons of AV fuel.
Could this all be from fouled plugs from tipping over the day before?
Did the sled get so heat soaked that it just needed time to cool off without any panels?
When the sled failed to start I was WTF do I even check?
I will post more as I think of it just looking for some advice for what to check and once I get a chance I will do some field runs and see what its pulling for boost and rpms.
mcx stage 1- purple primary with shockwave. 74 daltons in primary with b-w-b
Thanks
Tues.
Thanks
Tues.
