ZX thrasher hood
heynagel
Can somebody post a pic of the ZX thrasher hood from brtech.com? Ive been searching for one without any luck. If you a have a pic of any lexan or polycarb or even fabric hoods please post a pic. I want a new hood but I cant find any pics to look at.
Thanks in advance
More digging and found these. Black one is a thrasher hood right? Clear hood is the lexan hood. Can someone tell me the difference between the two besides their obvious color.
Any more pics out there of aftermarket hoods?
Thanks in advance
They are all very light weight. From my buddies sleds the lexan hoods are lighter than the mesh hoods but the mesh hoods allow allot better breathing. The down fall of mesh hoods is you can get your clutches wet easier. Others may disagree but thats what I have seen. Also BR racing hoods are Lexan, the black one you presented has been painted. The other hood looks like a Lexan Sno-Stuff hood again clear but it can be painted. Lexan is the lightweight plastic.
Fits: 99-03 MX, ZX & MXZ, 00-03 Summit & Highmark, 96-99 S2000 chassis. Also Polaris Edge belly pan. This hood has no headlight or windshield for the ultimate in lightweight performance(sno-stuff hood is cut for stock windshield and headlight). Upperpod design is of the DS650 and ZX lines. Cowel induction system for this upper pod design is $150.00 extra & weighes 1lb more with its intake assy and 3 2in tubes to duct air to your engine and drive trains vital points.Near same design as REV race pod. We will install the pod at no extra charge when you make your order. Weight - 6lbs. ZX cut, 7lbs S2000 or CK3. This hood is the ultimate design for aero dynamics in these chassis's This hood will give S2000 or CK3 3in. more pipe clearance. Will not accept headlight or windshield.
the black one is the thrasher hood that is made out of abs plastic not painted. the clear hood is clear lexan. i have read the lexan is lighter then abs. i just purchased the thrasher hood, its very light weight. i cant imagine a lexan being any lighter that you would notice a difference. i went with the thrasher cause i have not seen very many out there. vs lots of lexan hood
