ZRT 600 Parts, motor, stators, Black Magic pipes, DD shim kit, heads
ZRT 600 motor. It hasn't run since it was rebuilt. including new pistons.
-- pinned and welded crank.
-- D&D metal shim kit.
-- ported cylinders.
-- Black Magic monoblock head.
-- water and oil pump.
--$1000
$800 I have more than this in the crank, new pistons and monoblock head!
BlackMagic triple pipe. Turns 9200-9300. SOLD
ZRT 600 Used stator, flywheel and cover. Still ohm's out correctly. $150 $135
ZRT 600 Used Stator. Still ohms out correctly. $125 $110
Stock ZRT 600 head. (all three hooked together) $50 $45
D&D Shim Kit. Will need one new head since it was shaved too much and exhaust manifold bolt lifts the head..... Use base gaskets on both side of the shim. $125 $110
(2) new Arctic Cat pistons that are teflon coated. $40 $35 each (or both for $70 $65)
(1) Wiseco that was used for about 20 miles. $30 $25 by itelf,
1999 Thundercat 1000 used pistons and pins. There are about 3500 miles on them. Still look good. $25 $20 each or $60 $50 for all three.
ZL/ZR/ZRT black aluminum brake handle $10 shipped.
DSC00667.jpg DSC00668.jpg DSC00673.jpg DSC00674.jpg DSC00678.jpg DSC00682.jpg DSC00687.jpg
