Zbroz Racing Billet Upper 36" and 39" A arms available for pre order now
Z
Zbroz Racing
http://www.zbrozracing.com/polaris-pro-rmk-39-chromoly-lowers-with-upper-billet-arms-wide-package
We have pulled the trigger on production for the Billet Upper arms.
We will be offering them in Red, Black, Blue and Gold anodize.
Light, Strong and bad azz looking!
Uppers will compliment any lower Arm you have now or buy them as a package with our max clearance lower a arm.
Will fit 2005-2014 RMK Chassis.
Both 39" stock Pro RMK width and 36" width available.
attachment.php
attachment.php
Yes, if you have a stock 39" RMK a-arm package on your IQR...but not with the stock IQR, Holz or other non-39" front.
Upper arms
"would you be able to use these on the iqr?"
Mountain Horse is correct if you have an RMK style spindle on your IQR you can use the uppers. So stock RMK style spindle or the Holz spindle which came on some of the later model IQR's
I have been thinking sbout narrowing the front end on my 12 switchback assault. Will these fit, assuming i get new front shocks- Thanks
are you guys looking at doing anything to strengthen your bottom a arms?
Are you asking zbroz if they are strengthening them?
The current version is pretty darn bulletproof.
They are the strongest A arms available IMO.
The weak point becomes the upper ball joint I just carry Spares.
I had my lower a arm shear off while sidehilling
You obviously hit something solid right on the spindle where the only fail point is the a arm.......
The upper ball joint fail point works if the spindle can rotate from a ski hit......
Would you rather the upper was toast also? (Stock a arm)
Or a mangled bulkhead? (Skidoo)
Or a bent tunnel (cat pro climb)
No matter what sled or brand arms you used there would have been damage.
