Well, if you want to go with the budget build, you could have your existing shocks cut down to 16.375" long. Andy, at gasshockrepair.com will cut them down and freshen up both for probably just over $100 total. If you do that, I highly recommend that you get heavier springs. The RMK Assault springs work well. The part number is 7043611-133 and they're rated at 180 lb/in. Stock is 150 lb/in, which will tend to dive on you with such short arms.
Otherwise, there's lots of good aftermarket shocks. Fox, Exit, etc.
I've got a set of assault springs that I don't need if you want to go that route.
Will the assault springs work on 2012 pro WE's shocks?
Thanks for the info guys but not going to use stock shocks, was looking at the fox evol just dont know how long they need to be with the 36" kit.
The 36" kits use stock length shocks, which vary slightly by year 11-12 & 13-15..
