yz250 set up question
rmking700
New member
Hey all I've got a steel frame 01 yz250 im setting up as a snowbike. Running an esr345 kit, lectron, rekluse, etc. Bike is together and tuned in well for summer set up. My question is if anyone has put a kit on a steel frame yz250 yet. I know the geometry from 99 and up is the same just not sure if bushings changed as ts list from 06 and up for the 250 2 stroke. Just hoping someone already knows what I may need to track down to set it up. Kit will be a 2019 raw 120 solid strut.
Just make sure with the steel sleeve in the kit you have cooling and heating the engine dialed so you don't catch the ring... you can get hot when the engine is not in the snow quick. Likewise when you in the snow you can't get warm...engine jacket with the tunnel cooler is the easiest... or at least evans...
Sent from my SM-F900U using Tapatalk
