YZ250 fit kit?
shortstuff
Does anybody have any idea why the timbersled fit kits only say they fit 06 and newer yz250s? 2005 was the first year they were in the aluminum frame. And the only things I can find that changed from 05 to 06 is the forks. I have an 05 yz250 that I want to put an aro on. Just trying to figure out why they wouldn't list back to 05.
Sent from my SCH-I545 using Tapatalk
they have no listings for install kits on the new aro. they might be different. only time will tell.
I have a 14 st on a 2005 yz250. I used the fit kit from my 13 wr450 and it all worked except for the two bushings on the left side of the subframe to the bike. You'll probably have to make your own bushings unless the 05 does infant have the seamen dimensions as the 06 and up as we both suspect.
2005 and newer all fit the same. 2005 was the first year of the aluminum frame and everything from there up would be the same frame to motor relationship.
