Recommended fork rebound and compression settings? Haven't ridden it yet and snow is a ways off. Wondering what initial setting works well ...
Sent from my LG-H873 using Tapatalk
Working on homemade airpro - have fittings ordered from Ackland Grainger - pretty simple to make - air hose fittings are only $4-$5 apiece total cost to build about $35 ....just waiting on shipping ...
So if reports are to believed that it (airpro) works for most riders as well as a full spring upgrade ....where is the best place to start re shock settings?
Thinking its pretty straight forward. Line from each fork to a tee with a schrader valve. Simple air line tube and fitting rated to 150 psi which is more than adequate. Ordered the fittings for the fork from Ackland Grainger. Should have them later this week and can confirm fit then.Can you make a thread with how you’re doing this?? I would definitely go this route!
hey Couch. I know this is an old thread but did you ever make the homemade Air Pro kit from Acklands Grainger!Thinking its pretty straight forward. Line from each fork to a tee with a schrader valve. Simple air line tube and fitting rated to 150 psi which is more than adequate. Ordered the fittings for the fork from Ackland Grainger. Should have them later this week and can confirm fit then.
https://www.acklandsgrainger.com/en/product/MALE-ELBOW,45-DEG,4MM,TUBEXR(PT)/p/WWG36X263
