Injector wires as stated above, or power commander. My sled half way through the day started running like that(kind of), make a climb come down with low idle and die, really bad low end bog, once it died you could wait 5 sec and it would fire right back up and run decent then start doing it again. when it would bog if you pinned the throttle it would bog for a split second and then take off like crazy. I wound up adding the full 10% on the PC box at low and upped my fuel pressure by 3 psi and +5 all the way across at 3000. then the sled ripped the rest of the day. I'm not sure if it still needed it because the next time out my crank went 6 miles in.
I think with the PC if your not in the perfect rpm slp recommends it will screw with everything. further more if your clutching pulls different throughout the range(as your would) the map is not set up for it, if it creates to much heat and the stock pipe sensor kicks in and says its to hot then its a hole new problem as the map is created for one setup and one setup only.
There is a ground on the upper bolt on steering lope on my 09 m1000, very hard to see. the bolt goes through a nut sert and then the ground goes on with a nut to hold the ground. I tried to loosen my steering post and stripped the nut sert and broke the ground. Pretty stupid design.
