He's obviously doing awesome, but how do you think he'd do with the narrower front end on it?Yeah he’s going to pass me up in no time. I can’t wait.
EVEN BETTERHe's obviously doing awesome, but how do you think he'd do with the narrower front end on it?
I think it would be much better. We do have the skis on the narrowest setting but I think it would even be better with the narrower arms.He's obviously doing awesome, but how do you think he'd do with the narrower front end on it?
Probably not. I think there is something lacking in the clutching for the elevation we ride for sure. But I wanted to try it out stock but yes I need to get different clutching I am sure.Wondering if he has the right clutching. I can get the Yamaha version from my buddy but he says the clutching is way off and parts are on backorder.
overloading the springs and squishing the sled down closer to the ground will make it harder to tip up as well.I took Isla's Blast for a little spin and even with me being 6'5" and 240 lbs that thing really liked to be planted. Granted it was in 4" of dust on frozen ground...
I removed 2 of the 6 weights to get more rpm. Opposite side, three hit rev limiter. Ride around 10k. Short term bush fix until someone figures out a high elevation clutch kit.Probably not. I think there is something lacking in the clutching for the elevation we ride for sure. But I wanted to try it out stock but yes I need to get different clutching I am sure.
Running 7800ish now with 3 weights TS hit limiter very quickly so I do not know.I drilled out the weights. Runs about 78-7900 now. What’s it limited to for revs?
Just got the clutch kit. Arctic cat part 8639-413
They are 8 gram weights vs 12 gram stock. Should be the same as removing 2 except balanced.
