Yo Fredw
Tests were done from 3500 rpm thru 8500rpm.
1000 rpm per second
then backed up with 500 rpm per second rates after fuel curves were quantified.
Engine water temps at start were 110 degrees.
Intercooler water was 65 degrees at start too.
all reeds required fuel changes for fair evaluations. the stiff ones are lean the soft was richer of course.
6 psi was the base, mobil 89 octane. 14% ethanol. pump says 10 % but you know how that goes too.
its time consuming but well worth it in the end. Good luck and bravo for stepping up and being the first to think outside the box
Gus
Well Fredzo,?
Any luck getting it all together ?
Do you guys have ridable snow yet ?
Have a safe and fun season man.. good luck to you and yours...
Gus
nothing yet gus, still waiting on brp reeds, put the tony ducas in this last week, and plan to get out over the next week, from low elevation riding with the ducas installed, seams like bottom end is more than before
