Yeti tunnel cooler hose routing
simbatheking
I was curious if anyone has a tunnel cooler on a ktm/husky 2 stroke so I could see how you routed your lines as it is very tight at the connection between the Rh rad and the water pump
Bumping thread to the top. Interested in more discussion on the yeti tunnel cooler in general, routing, who is using them and how they work, etc.
Simbatheking, did you get your installed/routed? How's it working?
I got it installed. It’s more work than I thought. Had to remove driveshaft partially in order to do a good job of it. U could do without but it would be a f#ck around. Fits great and is nice and compact. Just going to hook up the lines tomorrow. I already have turbo coolant lines running back there so I’ll just tie into them
