Yeti bearing/shaft removal tool
I am just finishing up a track swap on my 2016 Yeti, I have the Yeti tool, but if you have a good quality puller I think you should be OK. You only need to remove the right side drive axle bearing to change the track which easier than the left side. There is a good video on You tube that Yeti posted that walks you through the procedure. Good luck!
The tool works very well. We lucked out and were given one due to alignment issues on SS kits. I've done it with a deadblow hammer also though.
