I
insomniac62
First of all, I apologize, there are SEVERAL threads related to this issue...
I have searched myself and tried to follow others fixes to this issue...
Problem: Sled BOG's at 6400 - 7200 RPM range. If it makes it out of this RPM range it almost rips my arms off...
When I first bought this sled it was in August ( yes, horrible mistake I know) First took it out, had this bog. Initially took the power valves out and cleaned them up. One was in backwards....overlooked when buying cause it was a such a "good deal" and I wanted a sled for my wife before the snow flew that year...
Anyways...Powervalve in backwards, scuffed the piston rings but still held good compression. Power valve seemed free (when out of the sled) but when bolted in place it was bent enough to where it wedged itself in place. One bent, neither powervalves would open, VOILA, new powervalve, gotta be the problem...NOPE
Things I have tried:
Tail light wiring - OK
Hand/Thumb warmers - OK (all currently unhooked)
New Plugs
Ground behind coolant bottle - OK
Motor mounts - OK (replaced one)
Torque stop - Slightly worn but ok
Clean PV's
PV cables EXACTLY 34.5mm or 1.35" (checked with Dial Caliper)
Secondary spring - Checked Rollers when replacing spring - OK
New Belt
87 Oct fuel(NON ETHANOL) - fresh
Weights are all the same, Centered, and all set screws accounted for
Ecu Connections all look good
Things YET to try:
ECU swap
Check Stator
Ignition Coil
Kill switch disconnect
Primary Spring
Clutch alignment ( best way? use the alignment tool?)
Plug wires
Swap Servo / Verify servo with sled on a stand
I have NO codes flash, and on a stand (No load, not holding brake) it will walk all over 7800 - 8000 rpm
Here is a link to a few short clips of the sled running, maybe hearing it someone can help me decide what next step to take.
Thanks to all in advance.
http://youtu.be/aTOc-ziyrmk
second part of the video the throttle is wide open, pitch of the motor changes but throttle position remains the same
New Plugs
Clean PV's
New Belt
Things YET to try:
ECU swap
Check Stator
Ignition Coil
Primary Spring
Plug wires
