Yamaha v-max 600
anything 2 stroke, 94 -06. watch for cover height after 98. same clutch, longer spring, taller cover. some had different diameter pins, 8mm or 9mm id. other than that, most parts interchange.
2000 and later YVX's also have beefer ( thicker) cast sheaves down towards the center of the clutch. They are a little stronger, and slightly less prone to cracking down low. For a 600 the earlier ones should work fine, if in good shape.
