I have the same therory about the header wrap and the hose clamp, That is what I have planned for mine.I forgot to mention that. It was a turbo specific pipe that I ordered from cpi. cpi makes it with a little bit thicker gauge metal and it is specifically made and designed for turbo's.
Don't use a normal cpi pipe designed for a NA sled on a turbo sled.
Also forgot to mention that after I header wrap it I put two high quality hose clamps over the fat section of the pipe. cheap hose clamps from home depot will break in a couple weeks. I got these from parker/fluid connector. I did this to hopefully hold the pipe together and cut down vibrations in the pipe. Like SLP does on their pipes. You can actually order the hose clamps (good ones) and a strip of header wrap from slp.
I paint the pipe with VHT flame proof paint before I header wrap it. Best to have a local powder coater aluminium oxide blast it before you paint it or the paint runs super easy. It will also flake off after it gets hot a few times if you try sanding it or don't prep it at all. The spots you don't sand it really well is where it will flake. you will spend hours and hours trying to get it all sanded down good. I got it blasted by the place I use all the time for $15.
dont mean to be debbie downer, but dont use those flex things, i bought a REALLY nice one and had it on my yamadoo... blew out after maybe 600 miles. thats why boondocker stopped putting them on the sidemount apex's..
2 strokes should last longer as they are less pipe heat.. but still, hate to see your turbo eat something because of it.
maybe i did get some cheeper ones. who knows.. i hope they work out.. just didnt want to see you throw something together and have to cut it apart and reweld after a few rides.That's not what I wanted to here I got the idea from my turbo builder. Also I got the ones from vibrant that are made for turbo applications they have a interlocking inner so they hopefully will hold up I already cut the head pipe down.
Sent from my DROIDX using Tapatalk
