xp turbo carb flanges
BSP is offering these in 2 forms.
std for 40mm rack mikuni ( turbo )
std WITH injector socket for AIC or Boost-it additional injector control.
$275 for carb only
$375 w/ socket
price is per set.
includes rubber oem rotatry valve type connection for carb.
this is ALL aluminum,,
Gus
603-401-8897
Does the turbo system you are building/installing for the carbed XP using electronic injectors? Or is this for the new e-tec?
If for carbed systems, do you still have the same problems that are associated w/ power jets as where I understand it isn't so much as the extra fuel once boost is up, but trying to find a base jetting that is still responsive when boost numbers are low or off and on the throttle? I realize there is more to it that. So a basic response w/out giving away any secrets/specifics to your setup would be greatly appreciated.
Thanks
Hey Bryce, I am also interested. Let me know the scoop when you get the details. See you soon.
sorry for the delay guys.
during some evaluations we found a harmonics issue that foamed the fuel at most operating rpms..
no solid mounting here ,, bad idea..
back to good ole rubber..
Gus
