Yep, same here on the wifes 09 XP, seems that the right side doesn't want to stay tight.
This has been posted before. One fix is what you mentioned with the velcro, the other was to put a bungee cord around the hood and let it sit by some heat over night. I did try this method and it worked for a while. I'm going to try the velcro next. Doesn't seem fair to spend $10K on a new sled and have to use velcro to keep the hood from falling off.![]()
If we're talking about the hood on the Xp I have fixed mine. I noticed the problem after we put the 09 air filter on the 08 sled, that's when the hood kept coming loose or poping away from being seated.
If you look under the hood (at the high end around the head light) there are 2 little tabs or nubins which hook or pop into the main housing, I took the Fien Multi Master and cut a void or notch in the tabs or nubins so that now when you put the hood on the tabs or nubins pop in their sockets and the notches I cut into the tabs hook the edges of the sockets or holes and keep the hood firmly in place.
I can email photos if anyones interested.
Tks Will
