xp bog
on my XP when I hit a hill with a steep transition I have a bog when I impact the hill and then clears up after about 10 feet. It only does it when your on the power hard. Im not getting powder over the hood.
Its becoming an issue
Check with your dealer, there is an issue with SOME XP's with the carb needle jets being not sncyronizied (sp.). SNoJo's has an issue also between 5800 where it jumps HARD to 6400 rpm. Going in tonight.
No tnoticeable when ya pin it tho, gawd shes CRAZEEEEE on this sled.
hope this helps.
Xp bog
I had a flat spot in my throttle response. It would go to 5700. Give it a little more throttle and nothing happened. A little more same thing. Finally I gave it enough and it would jump to 6700 and run fine at full throttle. My dealer cleaned my carbs and the problem went away.
