XP and REV rear axles the same???
I want to put 8" XP wheels on my 2004 Summit and I was wondering if anyone has done this or if anyone knows what sizes the axles and bearings are? I am getting extensions and an axle (to run 2 inside wheels) from wildchild. hoping i can buy stock XP or Cat wheels and put on there. any info is helpful!
The xp runs a smaller bearing 20 mm and the rev runs a 25 mm bearing, just buy new bearings and your good to go.
NTN 6205(25mmID./52mmOD.) or whatever bearing maker you prefer. SKF, Fafnir, etc...
Any bearing supply can compare & cross reference to get what you need.
I believe the width is 12mm, I'll doo some checking, get back to ya. Would you happen to have the bearing # from XP wheels? I am pretty certain of the Rev using the 6205-rs2, not positive what XP #'s are. If they are 6004's, then the OD. is approx. 40mmOD.
I haven't had my wheels off yet, and I'm at work right now-unable to pull and check 1 right now.
