xm mid range bog?
C
sled kicks butt has slight bog in mid range, stock other than bikeman can with aluminum heat sensor du dad, anyone tried a y pipe on them? any ideas on bog, its not horrible but noticable
Matte Murder
3,579
2,258
No bog on ours. One has the complete SLP set up and another stone stock. I have heard of ETECs with a bog in break in(rare, just heard about it, never have seen it in person) and when really hot they bog like heck. Maybe the sensor thingy is giving a false heat reading.
E
Ed Fast
690
88
Gillette WYO
Can
I ran the bikeman can had the bog and could not hold rpm. ran it over it a fit of rage. I suggest you do the same.
C
just put stock suitcase back in. riding tomarow ill see if that helps, its not a serious bog and it could be break in. Have 80 miles. snow is awsome, tomarow should be another kick *** day.Have 2 pros, and there is no way ill be able to get back on. xm,s are the real deal.
winter brew
4,332
LakeTapps, Wa.
Get it through break in, if it still bogs with the stock can then try clicking down.....if it still bogs with the aftermarket can I would say it is the can.....they are sensitive to exhaust changes and engine load. Or it might just go away after a few more rides.
J
Mar 23, 2011
9
Mine does
When the air intakes get covered with alot of snow. Had to clean them from time to time riding in 1-1,5 meters of snow today. Other than that it rather bogs a little just when you get on the throttle to get the sled moving
