SpencerA
Ok so since my I got my sled back together its been a nightmare with cooling issues. The guy who did my sled mounted the coolers under the tunnel for better cooling. As you can see in the picture they come up right by the coolant reservoir. He had problems getting the air out of the system so he installed a clear tube between the coolers to make sure coolant was flowing. You could physically see the coolant flowing great. Got about 3 miles in and the hose actually burst (Look at pic of hole). Now I'm not a mechanic but the hose he used was much like a fuel hose but much bigger. Isn't a cooling system have a lot of preasure and thats why that hose burst? So I'm obviously going to change it and run some actual cooling line between the coolers. So I need help getting the air out. I've read that you get the front up high. So how high, and what steps do I take to insure this system is completely free of air. Oh yea and everything has been eliminated from head gaskets, o rings, water pump etc etc. So the airlock has been the problem.
Last question is it bad to go slow on the trails with these motors? I sometimes go with my family and my pulls a snowcoach so she has to go about 15-20mph. I try to get in the soft stuff on the side of the trails as much as possible. My motor has a few mods, pipes, heads, porting, clutching. Seems like I heard that you need to wind the motors out so I don't overheat and carbon build up?
Any advice would be very much appreciated.
