X Truck Sled Deck
2
2thirteen
New member
Just wondering if anyone has any experience with these decks. I have one and am currently in the process of installing super glides, super clamps, extension, wiring, etc... any info or tips would be extremly helpful! Its going in a 2012 F350. Thanks!
bought one last year. seems pretty descent.the finish on the wood will peel where your skags hit. and the bolts for the catch for the super clamps is not long enough . mine would only grab about 2 threads on the nut that is welded on the bottom side . had the sleds loaded when we figured that one out .went to snap the clamps and it pulled the bolt right out of the deck . made some longer ones and it worked great . and the ramp folds which is nice but can a little clumsy if you are loading by yourself .
The bolt for the Clamp was the first thing I checked because I heard of that issue happening to other people as well but mine seem to fit. Almost thinking I might have to cut a bit off to clear the ramp underneath. Do they fit fine in the outter holes? Also how did you wire it? I plan on wireing it to a plug and just plugging it into the one for the trailer. Thanks!!
Also what size do you have? I got the 7' and plan on getting the extension but when I went to get it they were going to put it on for me and it wouldnt fit right but I have seen them on others that fit fine. Any experience with this? Thanks again!
