wtb turbo/supercharger for Apex
flybyu, that would be a 2854 turbo from your CPR kit.
I have a first year Powderlites kit with 2554 turbo to go on a stock motor for $3500.
Are you interested in the following, will save you a lot of work
Due to unfortunate circumstances, I have acquired this sled from my friend and wish to sell it. It is a 2007 Yamaha Apex RTX, approximately 2000 miles with the following additions
  • [*]MPI Stage 2 supercharger kit with special carbon fibre belt, several sprocket sets to adjust boost
    [*]JE 10:1 low compression pistons, Falicon supercrank, Falicon Knife connecting rods all installed by 2K Mototsports of Richmond, Minnesota October/07 prior to installing the supercharger
    [*]Vortech blow off valve, Bosch piggy back fuel pump, 128" rail extensions with 128" Cobra Track and 255 1.5 inch studs, O2 Sensor, 9 tooth Anti Ratchet Drivers, Barkbuster Front End Kit all installed by Ulmer Racing of Menno, SD January/09
    [*]Team TSS-04 Secondary
    [*]Heavy hitter clutch kit
    [*]Dual Digital Water/Oil Temp gauge
    [*]35lb analog boost gauge
    [*]Ultra lite Wide Band Air Fuel Ratio Gauge
Running 300-320 hp at 18 lbs. of boost. Allan of Ulmer Racing confirms this is a strong, well built sled. The sled is in excellent condition and ready to run. It is located in Ada, Minnesota and available now for sale. WELL over $20,000 USD invested, asking $15,000. Call Ron @ 306-782-8454 weekdays, 306-782-0895 evenings.
