wtb blown up or wrecked mtn max
I have one for you in Cheyenne
I have a 97 Vmax 700 triple (same chassis as MM) with a 136 track and "big boy" suspension with long travel kit. This has a running engine with about three hundred miles on crank rebuild by SLP. Throtle stuck and it hit a tree! It took out a shock and trailing arm, warped the hood and mangled the exhaust. I have already replaced the trailing arm and shock. This would be a good fixer upper sled. I have most if not all of what is needed to put it back on the trail. Bulk head is good and straight. Let me know if your intersted.
-BD1
pm me if you interested, have an 03 viper mountain 144 with a hole in the crankcase. I have all the parts to fix it (bottom end out of another motor, new head, etc) except for the center cylinder/piston/rings.
