Looking for a used tki belt drive kit. Per the webside they want The recommended gearing for turbo sleds is 2.25(26T) and a 58 lower. I am also looking for avid 3.0 drivers for the same 2017 sled. Thanks!
Ok thanks for the info. Note i have a high octane boosted intercooled sled.I would go with a 25 top gear. But it will give you the most only if you do some clutching.
Most guys with boosted sleds want to gear up. I don't always agree with that because if boosted you are more likely fighting some lag and heavy primary weights before the boost comes on. In this case it is better to gear down and get into the boost sooner. This applies more for tree riding and not so much for chute climbing.Ok thanks for the info. Note i have a high octane boosted intercooled sled.
After looking up what gear's mine came with stock I agree with you. 25 top and 58 bottom gives you close to stock gearing.Most guys with boosted sleds want to gear up. I don't always agree with that because if boosted you are more likely fighting some lag and heavy primary weights before the boost comes on. In this case it is better to gear down and get into the boost sooner. This applies more for tree riding and not so much for chute climbing.
