WTB...2005-2006 polaris 900 engine
will sell full 2005 975 carls cycle big bore. 900 based motor w/1800 miles and 200 on rebuild for $1850 w/ecm and clutch spring/weights for this setup. Bolt up to any 2005 or 2006 and go. If you have a 2006 then it will still work you'll just have extra injector wire plugs but no a big deal. This is everything you need and about $1200 savings from just the big bore and clutching setup originally. have recipts to prove it.
PM me for interest.
Will not pull motor until I have $400 no refundable deposit. As I am going to an 1140 depending on motor sale.
975 is a monster and pull go sled. runs very smooth with no problems or mapping to do as carls has the ecm flashed to run their specs. It must have a 60/40 pump gas/race or av gas mix.
Pistons, rings, pins, bellows, topend was replaced last season as it had been 3 years and I only got to put about 200 miles on so its not even broke in.
you also need to know exactly what year 900 you need...the 05 and 06 900 motors are NOT the same top end, and use different injectors (2 vs 4), steering columns, oil bottom, colant bottles, ecus, cylinders....
so state whether you need an 05 or 06 900 motor to help you get what you need. ;)
I updated the post with all the specs.
Also I will sell just the bb kit (topend from pistons up including head, bellows, clutch spring, weights, helix.
full BB kit and clutch tuning to go with it basically for $900.
This is an awesome kit and was around twice that new without clutching.
