Wrap coming off
donbrown
So we put on a wrap and some of it is coming off the sled on the concave parts.
Should I remove those sections of wraps reclean the area with alcohol?
What adhesive should be used to reattach the wrap?
Did you apply it dry the first time?
If you did apply it dry, and there isnt any kind of fluid/ film under the wrap then you dont need to remove it. You can just apply heat to it and get it to lay back down. remember, you need to get it to 180* for it to form to the shape you want it to hold.
If you applied it wet, then yes, you will need to remove it and clean it with a alcohol / water mix. when you clean the wrap material, just spray it with the solution and dont wipe it with any rag, just try to flush it clean with the solution. Then after its clean and dry, re-install the wrap DRY and use the heat gun, dont use any extra glue.
Applied dry with alcohol, surface cleaning.
Since it is so cold Im thinking of peeling some of the little ones off and then wait till summer unless I heat the enclosed trailer overnight
