I'd be willing to bet most of that claimed weight loss is due to the oil in the oil tank. less than 10 for all the hardware. On a 600+ lb system (you+sled+fuel) are you really going to notice 10 lb right out of the middle?
Wasn't mentioned, but doo's DPM worked damn fine, best of all the OEM 's altitude and temp enleanment schemes. Stock or mod, they gave you lots of flexibility with mods for little coin if you knew how to jet flatsides. Liked the simplicity back then, still had a temp sensor, but it was very rugged. Very seldom would DPM fail if you maintained the sled, easy to test, easy to fix. If I had to go back, that's where I would head first.
Are there a few posts insinuating that you are concerned about issues with the fuel injection system? Granted I'm sure there have been some issues, but few and far between.
Patience young grasshoppers...snow will be here before you know it!![]()
Yes! We build a 2013 Pro with Carbon Fiber body parts and Titanium suspension and bolts with a PAR 1100 in it. We opted to go with LECTRON CARB for light weight and tunability. If I remember right we lost 10 lbs going with carbs (this does not include removal of the oil system). The sled runs great. Carbs work awesome when set up correctly. It does take a little more time and know how though.
It is interesting to notice that all 3 manufactures are running carbs on their snocross race sleds too. I am curious whether carbs will make more power on an identical sled with EFI. Considering taking two pro's and getting a CDI and carbs for one and running them side by side to see if there is a difference. Hardest part is that the motor will need to be raised up a bit for the carbs to clear the Jackshaft.
Bingo! The Lectron is key here. The Miks are absolute junk! Finicky, overly sensitive junk. Lectron's newest owner has spent a lot of time in redesign and development for two stroke application. I have one on my WB165 Husky (a big bore 125) and it incredible. The power is smoother and the carb works well from sea level to 6,000 feet and temperature changes in excess of 40 degrees- ALL WITH NO ADJUSTMENT. Because of the design, it has somewhat of a compensating ability. My TMX couldn't stand a 5 degree change in temperature or a 200 foot change in elevation and I was always jetting it. If the manufacturers had ante'd up and bought Lectron carbs we wouldn't need FI now.
Sweet,which flywheel,stator and cdi do you use on this? Are you using mikuni tps?twin pipes?Yes! We build a 2013 Pro with Carbon Fiber body parts and Titanium suspension and bolts with a PAR 1100 in it. We opted to go with Lectron Carb for light weight and tunability. If I remember right we lost 10 lbs going with carbs (this does not include removal of the oil system). The sled runs great. Carbs work awesome when set up correctly. It does take a little more time and know how though.
