Would timing module benifit my pump gas m1000
shadow conspiracy
I have a OVS pump gas m1000 running at 5lbs and currently mixing in a few gallons of AV fuel with every tank. Curious on the benifits I would get if I used the timing module.
Should give you better bottom end. With the AV gas on a pump gas setup, I don't think you will have a big benefit on the top end.
PM/contact Travis or Garr. They know the kit, they'll have your answer.
What elevation do you ride, unless your under 6000ft I don't think you need anything but pump for 5lbs.
Where he's at I'd bet he's under 6k a lot. Highest mtns near him are 8k & they start WAY lower than we do around here.
Elevation around here is 3500-6000ft. Turning the boost up i don't think is an option unless I upgrade the fuel system. I was thinking the module would allow me to run straight pump gas with no worries but I'll sacrifice some power which might not be worth it.
The only worry would be if you ran out of injector flow, I don't know how efficient your kit is but if you think you could flow the fuel when turned up I think the timing module would benefit. A friend with a bd was running 8lbs on pg at 9-10000ft,
