B
b2krawler
New member
2005 rmk 900, 900miles on sled, just got done putting an SLP air box on, already had the pipe. sled ran fine before air box install. Sled ran fine for about ten minutes after install, but then the hood wiring harness melted against the pipe, fused several wires, sled started to run very poorly, sounds like only 1 cyl (getting spark from both), backfires, etc.
the sled did not like going into reverse w/o dying after install
I thought it may be a capacitor or TPS problem, but the sled ran fine until the wires melted, the display went nuts when this happened. i fixed the wires, but still runs poorly, even if the hood harness is unplugged (it should run fine with this unplugged, right?)
so what potential problems are associated with melting those wires, i guess i could have fried any of the sesnors or the ecm with all those wires touching?
is there anyway to retreive codes with engine off (hook up a battery?)
Where should i start?????
