tlm700, thanks for the tip! i called the local napa store and gave them the ballcamp # 755-1598......for $3 they delivered it to my shop. plugs right in. i will be riding tomorrow and testing it out with the heated shield. hope the 2 amp fuse is enuff. also, it is a double ended plug that you cut into 2 pieces, so you really get plugs for 2 sleds
I post this with complete respect for cwbyup_232 and I'm only trying to be helpful. I've been looking into the electrical system on our DC-CFI-2 RMK's and have some decent insight into the system the I hope others will find helpful.
Actually the amp mate n lock connectors are ONLY for the Power INPUT for the ECU and DigitalWrench console.
The connector labled "DC PWR" is a Power input for the diagnostics.
That connection is un-fused and could wreak havoc with the ECU function or durability.
Best to tap into the FUSED connection in the hood harness and do not run anything off of it that will draw more than it is fused for at 2 amps...REGARDLESS of what others may be saying.
The red/white wire powers draws from the same red wire, through the chassis relay, that powers up all the vital functions on the sled like ECU, Fuel Pump, sensors, MFD etc.
If something goes wrong or shorts there... then you could have an expensive problem on your hands... easy to do since that is not fused.
IMO... DO NOT use the "DC PWR" connector for to power up ANY device... Any aftermarket items that run off of this connection are putting your sled at risk and should be changed to the fused circuit. In some cases, the aftermarket mfgs of dc powered items may be making assumptions that could put your sled at risk.
A couple of questions...
Where are you tapping into the red/white wire?
What do you run off of your power point?
Did you change the fuse for the power point to anything other than a 2amp fuse?
A 2 amp fuse would give you plenty of power for the mfd and taillight. Install it at the point it taps off the battery.
