Wire for hooking up avenger 3?
I have 04 summit wiring harness in a 07 chassis. Could someone tell me wheres the best place to tap in for the RPM? I trying to hook up a Avenger 3.
thanks
H860:confused:
Yep tap into one of the 2 yellow wires....both wires off the gauge.
Tried mine out for the 1st time this weekend.
I know the digital gauges are more accurate but I was seeing 9 - 10,000 rpms when I'd 1st hit it in the pow then it'd back down to 8,000...engine sure didn't sound like it was over reving that high????
Seems to me like I might be getting false readings.
I guess I should have said I have a 3 wire harness. One has a fuse and the other does not and they 3rd is the ground which I just tapped into another ground wire.
