We will be carrying a cool new product that you may find useful for those times when your sled ends up stuck in the fresh stuff. Some of you may have seen it before, it is the Snowinch from Warn which has a line pull rating of 1500lbs. It also comes with 40' of Synthetic rope which will work whether you are pulling the sled from the front or the rear.
Price: $365.00 Shipped to the Lower 48
If you are interested in purchasing, please give us a call at 715-297-3461.
Specifications:
Rated Line Pull: 1500 lbs. single-lineMotor: 12V DC, .4hp permanent magnetControl: Remote Control 10'Geartrain: 3-Stage PlanetaryGear Ratio: 103:1Lubrication: Aeroshell #17Clutch (freespooling): Cam activatedBrake: Mechanical BrakeDrum Diameter/Length: 1.5"/3.0"Rope: Synthetic, 40', 5/32" diameter Fairlead: Synthetic HawseRecommended Battery: 12 Amp/hour minimum for winchingBattery Leads: 10 gaugeFinish: GreyComplete Kit Weight: 15 lbs.Warranty: 1-year limited
Specifications:
