Wimpy Steering Support
I've got a 2006 M, RKT 800 BB and 153 track, lots of other extras including a 4" rise CroMo steering column. Somewhere around 1400 miles on the chassis.
Basically I'm very pleased with performance but one nagging item is that I have a lot of play in my steering, due mostly to flex in the steering support bracket. The riser increases leverage and flex, but even at stock height it has always been easy to move the steering several inches forward and backward and an inch or so side to side just by leaning on it. The bushings are tight, BTW.
This amount of play must negatively affect steering precision, and I'd like to strengthen this weak link. Has anyone else noticed this being a problem? Anybody beefed up the support, or maybe added gussets or structure to keep the wobble down?
Thanks, I've seen those advertised but my problem is not in the bushings but in the aluminum support bracket.
I might just add a plate to gusset up the connection to the frame and see if that solves anything... unless somebody has another solution??
Try to send wildchild a PM.. I think he might make a brace for that problem!
