will a ho 800 crank work in a 07 800r
D
deep_doo
i need a new crank the dealer says i need to buy a whole short block. so what i need to know is will a ho crank work? and if not why ? i also found a 06 p-tek crank would it work? thanks for any help.
now i am not an expert on this one but from what i have heard the 07's had bad cases causing the crank bearings to fail. You have to get the cases machined properly to prevent this crank issue occurring again. Also i am almost 100% sure you can't use a 800ho crank in 800r cases.
No, the 800R motor is a whole different animal. You can just get the crank, your dealer knows better! The 06 and previous are the HO's. Yes the 06 is a PTek, but it's still the series III HO motor. Cranks are different.
I would give Big John a call at Sled Head Racing - (612)-718-3861
He can get you a rebuilt crank - all new rods and new bearings, trued, greased and ready to drop in for a darn good price. Now if your 07 cases have not been updated (line bored) I highly recommend you have BJ take care of that as well.
the crank and bearings are fine just the taper shaft is cracking you know the part the clutch mounts to
Call big john...He has the taper shaft you need, which I doo not believe BRP even offers
612-718-3861
you are right they do not sell it you have to buy a whole new short block witch seems like a waste of money to me i will be calling big john Monday.:face-icon-small-hap:face-icon-small-hap thanks for the great info
