will 7t 3.0 driver work to install a pc 2.6 on a 13 pro?
will the Avid 7 tooth 3.0 drivers work to install the 2.6 powerclaw track on a 13 Pro?
will the 7t driver effect my overall gearing?
what year drive shafts will fit the 13?
Yes, you can fit up to a 3" track on a 2013 with no modification other than the smaller 7T drivers
Yes, this will alter your gearing slightly, but with a taller/heavier track it should actually help keep your clutching happy
Well there is some speculation, but I know for a fact a 11/12 Pro Rmk driveshaft plugs right in without any modification or driver swap, but since you are changing your drivers anyways some people were successful installing a 2005 900 rmk driveshaft in with different drivers. I don't see why any 2007-10 RMK driveshaft wouldn't plug right in, but I can't confirm...
thats what I was thinking ...buy an older model shaft and install the new drivers on it.
The Avid 7 tooth drivers are the only option for the 2.6" PC track in the PRO-RIDE RMK's.
You need the 7 tooth for the clearance (this is a 3" pitch track and the 8 tooth drivers are larger in dia than the polaris 2.86" pitch stock drivers)... plus the track is taller.
The gearing will be a tad lower.. which is good on this sled/track combo.
The driveshaft thing has been beaten to death... check out the "drive train" sub forum at the top of the pro ride page.
In short... Only 2010/11/12 PRO-Ride shafts will work in the 2013 PRO RMK PLUS the 2005 shaft (all with the correct drivers).
2006 through 2010 IQ-RMK shafts will not fit.. they are too long (longer than the 2005)
Thats what I would do, Look on ebay or at your local salvage yard for a used shaft for half the price of a new one. Plus I think the 11/12 shafts are on backorder, so the availability is going to be slim new.
There was a Pro Ride chassis in 2010? Are you talking about a Rush?
