why wont my 07 m 1000 start ?
i was pined going up a hill, the sled just up and died... has'nt started since. its not getting any spark.. got any ideas ? i checked all the grounds.. im thinkin maybe stater but not sure ????:confused:
i went through this heart ache last year with my 08. It ended up being a stator. i would start there.
adam
I would grab a multi meter and start testing stator components. I would also check connections for possibility of moisture.
Hope this helps if there is anything else I can help you with let me know.
Jeff
My 07 ran great one day then the next it only ran on one cylinder. I have spark on all four plugs. Could my Boondocker box be bad or maybe an injector?
look for fuel on the plug if there is check the reeds. check wires on injectors as well.
I had a simular problem with mine last year turned out to be a connection in the wiring harness under the motor came unplugged. Plugeed it back in and zipp tied it together. So you might check that.
Same here only I found the loose conection behind the heat shield with the steering post.
